Gassem, think he might be the only one.Does anyone have one of those jet ski haven PJS motors?
Timing advance from stock at least 5 degrees, and "B" limited chamber will wake it up. Good swirl modded prop, or stock SXR cut to fit, around 12/17 with an 84/85mm nozzle and short pump cone. FREE THE PONIES.....Get the head milled for more compression and buy a FP that will work with your soon to be had 750 motor....lol Other than that save for a 750/800.
Not sure what is different than the Wescoast, but you do have to cut off the lord mount.CRAB I got a SXR prop I'm going to send to impro But how do I fit a B pipe on the Manifold Just some southern engineering? Like I said I got a Jet sport Manifold
I am curious of how that worked out ?Gassem, think he might be the only one.
When we talked last, he said his arms were about 1/2 inch longer......:stups:I am curious of how that worked out ?
quit poking my ear lolWhen we talked last, he said his arms were about 1/2 inch longer......:stups:
the fp headpipe bolts right on to a jetsport exhasut mainfold, that is what i am usingCRAB I got a SXR prop I'm going to send to impro But how do I fit a B pipe on the Manifold Just some southern engineering? Like I said I got a Jet sport Manifold
The electronics can be shared but you will need to split the 750 cases to properly tap for the electronics.
Could you explain more about this?
Is there a 650-750 conversion "How To" anywhere?
