Idok
F1pro
- Nations oldest muthaF+++kin city
i got a hood kit with bracket
the bolts for mounting the bracket were too long, even with my reinforcement and super thick backing plate. i had to cut almost a half inch off the bolts.
the nose peice wouldnt fit on over the pole bolt, had to grind down some fiberglass to get it to clear. one of the through holes for mounting was off slightly.
didnt realize you need to mount the pole in the braket before bolting it down.
the finish of the gelcoat is pretty rough and needs buffing, but i dont care and will probly leave it as is.
the slot for the pole spring is too far from center making it VERY difficult to get the spring on. you gotta stretch the spring longways to get it to fit.
the breather tubes are too long i cut maybe 2 inches off each one.
i think thats it...
the bolts are easy...they are availible at ace hardware, one nice thing about all the WDK stuff..
I had to grind my diablo nosepiece as well...just a bit though..
good tip on the spring and evey breather tube I havec ever seen has been a different length..they must just eyeball them and not measure precisely for those..
