- USA
How is my ROK getting air in the engine compartment? I got no breather tubes under the hood, so the only way it's getting air is through the RRP pole tubes...Any ROK owners want to chime in?
Hey Steve if you get a chance will you back out one of your breather tubes and see how much clearence is between the hood and the liner, please.i have breather tubes in my hood... maybe its a drill your own deal?
unless the previous owner asked for a non breathing hood
if you have a dual tube pole there shoudl be enough air for your motor and less places for water to come in if you seal it up right
Just to add what ADDICT said, the rrp will supply enough air, however the more air you make avaliable the potential for maximum power will increase. You just need to tune your setup based on the configuration you are running...In my experience they always run better with the hood off![]()
