Am i missing something but this looks like a great idea. i can't believe nobody commented on this. Do you want to make more? i cant be the only person that would want one. If you don't can i get a little more instruction on how to make. It looks super clean and strong.
mine went right together as well...granted, the pump shoe was already in it when I recvied the hull...
kawi 750 cable in there as well with a 61x motor, TLR 48 with stock throttle drum
here's a pic of the installed noserail....still ging to pull it back off and run a bead of black 5200 round the nose..
used 1" SS carriage bolts, a 1" washer and nyloc..........put the first bolt about 4.5 inches from the front edge of the turf, then spaced about 5" apart
it feels rock solid like you could pick it up from the rail
and ZERO holes thru the nose!!!!
