BrightE's
Paul
- Seattle, WA
I bought a primer kit to replace my choke system on my '04 Superjet, and little known to me at the time, I ended up having to drill out and dremal the screws that held the choke butterfly valve to the choke stem before pulling the stem. All those tiny screw that attach the brass valve broke right in half when I was unscrewing them.
I tried best I could to tape and stuff close the carb body and venturi, but inevitably, metal shards got spread around pretty well in both carbs. I am rebuilding both carbs at the moment anyhow, is there a way that I can best ensure all these shards and metal dust are gone before I reinstall them? Is there an acid or oil soak that will do a better job than Q-tips, carb cleaner, and compressed air?
