heres what is goin in the ski.
Bad bones girdle head flat topped
Riva girdle studs 10mm
Carbon fiber head and base gaskets
Hot Rods crank
Pro-X pistons machined Flat tops-336 grams matched set 82mm
half moon cut into bottom of pistons
Moon cut mached to cylinder sleeves
Ported 62T cylinder
Epoxied stuffed and ported 62t cases
Delta V-Force ll reeds
Porting favors low end on this one that what is setup for low end and mid
Exhaust port widening kept at 70% of bore width, port height was not raised
Dual 44’s SBN’s with prok flame aressters. and adaptors
Riva anodized spacer plate
FPP B mod pipe
dual exhaust w/TDR powerspray waterbox
carbon front exhaust outlet
Stock pump and nozzles "blue printed"
Stubby cone
Solos 13/17 concord prop setback
Duel cooling lines
MSD enhanscer
MSD stock improved coil
MSD plug wires and plug caps
WSM starter
Waterdawg Kustomz diablo hood/nose/billet latch
X-metal -4 pole kit with -2.5 inch steering system/straight bars + CG racing carbon chinpad and ODI grips—dual breather system
24/7 scupper
blowsion kickers
OEM hoodseal
blowsion aluminum battery box
Limiting rope
Fuel area filled and glassed with internal fuel filler
24/7 hoodhooks
JSS bulb style primer
Sato finger throttle
Blowsion bilge switch
Dueling rule 360’s with blowsion bracket
Wammer D cut carbon fiber rideplate
work 201 intake grate
Hot Rods crank
Ported 62T cylinder
FPP B mod pipe
Stubby cone
Duel cooling lines
MSD enhanscer
WSM starter
24/7 scupper
blowsion kickers
OEM hoodseal
Limiting rope
24/7 hoodhooks
