Painting my ski
norcal ex
X-H2
San Jose, CA
Ive spent the last 2 weeks stripping and sanding the crap out of my ski. it is just about ready to be painted. what is the absolute best stuff to use for skis? i have a guy to paint it, but i just want to make sure im getting the best...
Crab
thanks darin...noswad!
Seattle
I need to know also, I was looking at marine polyurethane from West Marine, the drawback is the slow drying time. 4hr to tack free.
Cross
X
WA
the best is still imron by dupont
I have to agree. I have painted a few skis and Imron is super tough and holds up well. Another nice aspect is that it is a single stage paint, so you dont have to worry about laying clear coats down after applying color. The only negative aspect is that you are limited on your color choices.
Mike Serlin
NOW SPORTING A BIONIC LEG
I use house of Kolors paint and their epoxy primer, Lots of cool colors. I used a thicker high solids clear coat and it has held up really well for me. Heres a link to the clear... http://coastairbrush.com/products.asp?cat=168
I purchased it all from http://www.coastairbrush.com . They have a really cool airbrush store in Anaheim and they even have a couple bada$$ custom airbrushed 550's...
Rickster
Matakana Menace
i use house of kolors for the candys and some others i started using southern polyurethanes products recently with great success everything they have is awesome and alittle more user friendly and customer service is #1 http://www.southernpolyurethanes.com/
Have you used the single stage from this company?
I'm getting ready to tear apart my SN/SJ and I would l8ike a nice single stage black to work with (First paint job myself).:purr:
I think Imron has limited color choices, but is a really durable industrial coating (I used it on the frame of a LandCruiser that I am restoring. It is also REALLY hazardous and you should use a fesh air supplied respirator with it
If you are doing multiple colors, a basecoat-clearcoat system will be best at hiding the ridges from tape lines but is a little more fussy to work with than a single stage paint. Most clear coats use isocyanates and are also very hazardous to where you should use fresh air supplied respirators. The charcoal filters won't cut it.
edit: you have a guy to spray, so the respirator thing shouldn't be an issue for you....
Crab
Seattle
Seems like Kawi used imron on all the 550's, super tough.
