SkiDaddy
Just Havin' Fun!
- Orange City, FL
Finally got my RN hitting fairly well off idle (for knee high waves, reentries, etc.), especially when riding up to a small wave, dropping throttle to see how it breaks, then nailing it.:woot: :woot: :woot: :woot:
Thanks to all here for the jetting help, encouragement, etc.:cool2:
So far the final elements of success have been jetting as best as possible as described at Factory pipe, Mikuni manual, Group K, Waxhead, Paul, etc.:hail: :hail: :hail: then switching to a lower popoff/leaner pilot.:biggthumpup:
Also, playing with the B-Pipe water screws. On my ski a 1/32 turn either way from nominal noticeably softens the hit.:aargh4:
Now, what else can be done to improve off idle hit on pump gas w/out going big bore, stroker, Lamey, TL, etc? My setup is fairly typical - 2nd over 701, RIVA/Magoo ported, ADA head w/33cc domes, limited B-Pipe, bored nozzle, freestyle cone, Carbon Tech LT reeds (sealing perfectly), Impros repitched & cutback Solas X prop (NOT a concord), rejetted 38 OEM carbs, stock FAs w/1 screen each, MSD enhancer, 3 degrees static advance.
Yes, I know I can cut the pump stuffer out, but I kinda like the great rough water hookup.
I've searched & searched. Is a Skat freestyle prop all I have left to do? Is water injection good for off idle hit? Other ideas? TIA!
