Superjet3
Waterlogged
- Jersey Shore
OK, I am running a unported 701 with a factory b-pipe, delta v force reeds, riva intake, dual NOVI 48mm carbs, 13/16 solas concord impeller, lightened flywheel, MSD enhancer, and @ 175psi compression.
I am currently jetted @ 110main 130low 2.3 n/s and popoff is @ 15-20 psi. The highspeed screw is out 1 1/4 and low is 1 1/2. I am loading up on the bottom end. mostly @ 1/4 - 1/3 throttle. It will clear up when I rip on top. I have tried turning in the low spped screw but it gets really lean up top and if I blip the throttle from idle it will stall. I also noticed the carbs are not running the internal fuel filters. Does anyone have any advice on cleaning up the bottom end? Paul sugested to try a 2.0 n/s and raise my popoff. I just want to get some more feed back on this.
