- Georgia
So fresh build I just got everything installed hooked up the battery and one click. When I press the start button now I get nothing at all! I put the voltmeter probes on the battery pressed the start button and no draw on the battery.
Then I put the negative probe on the block with positive on the terminal before pressing the start button it had great voltage this still had no draw when pressed so I assume the ground is good?
What else am I missing? I know there’s a potential to be the starter relay/solenoid but I kind of ruled that out since there’s no clicking? Any help would be appreciated I was hoping to get on the water ASAP!
