E350
- Sacramento Delta
Is that called a "Block Fox" ?
No it's called a good ten footerIs that called a "Block Fox" ?
Good from far and far from good, see them all the time walking down the streetNo it's called a good ten footer
I may actually cut some blue foam and stuff it in the recess of the pole, at first I was worried about the weight of the pole but I have a Superjet pole spring here somewhere if I can figure out how to make it work with this pole, this hull had a scupper already installed, I left it but yes the sellf-righting feature was foremost on my mind with that scupper.I like the foaming you are doing to the pole. In one of the RSKI riders videos on youtube they say don't replace your stock SJ pole with a two-tube breather-pole because the stock SJ pole has foam in it which rights the ski up to sideways when it is upside down in the water.
RSKI RIDERS | JETSKI FREERIDE | OREGON, USA
The RSKI Riders homepage is dedicated to our love of the jetski and mountain bike. We love to spend time outdoors and we offer some very high quality and unique products to our customers.www.rskiriders.com
I saw a couple of people say the yoga mat absorbed water but I tested a piece of this and it does not so I should be good to go., I do have more builds coming up so please let us know how that foam works out for you.I bought undermat neoprene foam from thefoamfactory.com the overall price is close to the same but you get twice the amount of material plus it's available in lots if thickness from 1/8 to 2". 3/8 HT underpad 17.5x48" is $21; 3/8 FF neoprene foam 24×80" $28. The FF pad feels a little softer too. I haven't used the padding before but I'm about to turf my superfreak so ill let you know how it goes
I got the info from @Sanoman I believe he has used it with success. He is a go to for all things turf.I saw a couple of people say the yoga mat absorbed water but I tested a piece of this and it does not so I should be good to go., I do have more builds coming up so please let us know how that foam works out for you.
