D-Roc
I forgot!
- Dirty River Rider
if you want to go no foam then check out my builld thread or scotty2t. if you want some foam, stuff rigid dow foam in it best you can. if you want to refoam and redig wet foam out next winter then use the 2 part 2-4 lbs foam from composites canada. install some drain plugs or duck bills at the back of the hull. have you thought of a scupper or oneway valve? now is the time to do it. just remember when you go diggin into your foam there are two alum tubes for cooling/syphon in there. good job finding some performance for your ski.
