they might not last long..the wall thickness of the tubing is thinner usually than the umis and ive been bending those allot latley..hopefully they hold up for you...you need to shorten the pole though to get your bars in the same place
edit: after looking at the pic better it looks like you just have them turned up...i dont like them like that for two reasons..
when the pole is on the hood your center of gravity is higher than it would be if the bars were lower..having the weight of the pole on the hood dosnt lower your center of gravity having your body that low is what lowers it
also its hard to put your elbows on the tray caps when getting up
taylor loves em though..i think it just takes getting used to
