Super Jet Leaking hood seal...Thinking of getting a watcon seal,are these Good hood seals??
any one use watcon hood seal are they water tight in wave riding??
I had a problem with my sj taking in some water and noticed the hood seal was pinch and bent in along one side . Anyone else have this issue or can recommend a hood seal that works well
Might want to try a ratchet strap with your current seal to see if it helps clamp the hood tighter. Can make one for real cheap . If it doesn't 't work like you want then get the wAtcon hood seal and use it with the ratchet strap.
If your talking about the octane hoodseal that Watcon sells- then Yes its a big improvement over the yamaha hoodseal, seals better because its a simpler (flat) design (that stupid vertical flange part doesn't get folded over). I Still need a bilge pump though as my hood has the stock air passages.
227
Its all about the surf!
Oceanside, CA
Most people replace there worn OEM seal with a Watcon because Watcons are WAY cheaper and they work equally as well. If your OEM seal is still good, then swapping it out for a Watcon would be a waste of money.
Sanoman
AbouttoKrash
NE Tenn
Check out the one cold fusion is selling.l know there is a thread on here,you will just have to look.
Post #2 is great advise
chadman154
#Itsonlymoney !!!!!
Dirty south
watcon seals are great, i put one on my old rn and had a ratchet on it also, when i replaced it the oem seal was clearly shot. I was a night and day difference
98gti
C@R H@ul3R
NW FL
I just got my second watcon seal, thay are great quality. DO NOT even consider a hydro turf seal, the last one I bought got thrown in the trash about 5 minutes after installation.
For the price and quality of the product you will not beat watcon. I have used the hood seal on my last three skis and I think I have turned three buddies on to them no problems, just a good seal. On the first one I used some extra super 77. The last two just cleaned up the seal area with Acetone and stick it down.
hornedogg79
dodgin' bass boats
Just looked on the CF website and it's a Watcon seal that they are selling. I used one on my FX and it worked really well.
Oem 120 something CF 70 something Watcon 23 something. Not only is the watcon a great product but a fraction of the cost of other options should be a No-Brainer
Anyone know someone in the socal / california / nevada / az /ut that carries watcon seals or would someone like to sell an extra watcon seal laying around the garage in socal oc/la area- Trying to get one by this saturday
Tmart
formerly superjet444
Middle Georgia
I'm sure you could call John Zigler, owner of Watcon, and you two could arrange something with shipping. Saturday def seems possible. He's John Zigler here on the X
Thanks Sj444 yea I called John from Watcon he was Super helpful , when you get a company that answers their phone promptly and is on top of it , it makes a big difference. I will definately be calling them again in the future
