F
Freestyleriverrat
Guest
braaaaapppppp!!!! :cheer:
superramjet, what is done to your 66e?
HOW MUCH ARE THE 1200 CYLS GOING TO RUN $the bore is large enough that it needs all the exhaust opening. I've tried it both ways, it runs better with them open. It also saves you about $400 in gas powervalve parts.
The 1200cc waterdawg cylinders run the powervalves because it has a larger exhaust opening to start with.
while a superstock 800cc 66e may hang with a lamey, a big bore 66e will kill any lamey, The comparison is being made with the small 80mm piston setup (to stay legal for your racing class) to a fully built 62t, stroked, aftermarket cylinder, head, larger piston, etc. The 66e platform is far superior, you are comparing a fully maxed out 62t platform to an almost stock 66e platform. You are also comparing 2 different ski with quite a difference in weight at least 100lbs if both hulls are stock. The 66e motor can go 87,88mm, with different cylinders you can run 98mm (1200cc) on the 66e platform, this isn't even factoring in that you can stroke the 66e also. I've ridden a couple of the best freestyle set up lameys. My 66e is better. I"m not even running the good stuff either.
Jeff weighed his 5mm pv lamey complete with, carbs, arrestors, complete pipe and complete electric and his new 1200cc, 66e motor (twin not the triple), setup like it goes in the standup, with complete electric, pipe, carbs and it was 15lbs heavier. Not enough to matter from the power it produces.
if you build a 66e motor to the level you built a lamey setup, you will make more power everywhere. the 62t platform is maxed out the, while the 66e is just getting started.
I want someone to tell me their lamey is making more horsepower, torque, brap, than this:
1200cc of lamey stomping power
Sorry, but I doubt your punched out single pipe'd 800 makes any more power than our full TJ built Superstock TWIN PIPED 800 with total loss, Full Specs, flat tops, etc. Twin pipes add a lot more HP than boring, any day of the week.
We will have to agree to disagree on this one.
Scott
Scott
54 lbs? Is it strong enough?I'll be running my 66e engine in a 54 pound hull :woot:
what does a blaster 3 weigh and what does your blaster 1 weigh? Do you think Tj could make your ski more powerfull by going with a bigger bore and stroking your 66e? You are also running different size pumps in both of them. I just don't think the comparison is fair, to come up with your conclusion. I don't doubt at all tj can build a better motor than me. I do have to clarify too that I'm going for bottom end pull and hit more than top speed.
He never said he made more peak power than a twin piped 66e engine. You don't think a big bore 66e will hit sooner than a little bore 66e ported to turn max RPM?? Hitting HARD early is what makes his a Lamey killer.
We're not trying to go 75mph here...
Have you ever ridden a big bore (85cc-87cc) 8mm-10mm stroke PV Lamey with all to goodies?
Again, we will have to agree to disagree. Yes, TJ could make the 800 faster with more bore and stroke, but he could also build a 10mm 87mm bore Lamey. I was comparing apples to apples, 800cc to 800cc. Have you ever ridden a big bore (85cc-87cc) 8mm-10mm stroke PV Lamey with all to goodies? Makes sence to think it would be substancially more power than an 800cc race legal machine.
Scott
hey superramjet...
How long can you ride that demon of a ski you have before it's out of fuel?
\I'd check for leaks ! haha !:cool2:its a gas hog around 30min on five gallons
