...Superfreak Circus that is.
This is my third superfreak and first pure flatwater build. I have tried to build all around skis that would be able to ride surf and flat. My badass build was largly successful and a great ski that is still at home in big surf or riding on the lake.
http://www.x-h2o.com/threads/105023...for-2012-Daytona-Freeride&highlight=homegrown
However, I have found there are limits and compromises to a dual purpose ski. In the end, I was even changing rideplates, bars and steering system length to optimize ski handling between flat and surf. I wanted to to add total loss, powerfactor pipe, smaller tank, etc. but didnt want to compromise reliability,etc. for surf. So finally able to afford a second build and have separate skis for flat and surf.
Tem from Superfreak has knocked it out of the park again! Lots of innovations in the design of the Circus hull.
Again trying with this build to see how far a smaller less expensive motor can go on flatwater. Also can it push such a large pump was big question.
Thanks to Tem for awesome new hull, Blue for another great motor design and build, Zach at PHP for new lightweight stroker crank and manifold, and Billybo for paint/turf and most of the build!
Specs:
Circus full carbon hull and hood
XMetal comp length adjustable pole
RRP fatbar steering system
JetManiac/Blue new BB828cc motor with 4mil powerhouse crank
Novi dual 48 freestyle carbs
Powerhouse billet 2 piece manifold with VF3 reeds
MSD Total loss with zero lightened flywheel
Powerfactor Pipe
JAZ 2 gal tank
AG battery-so far
Skat 155mm 14vane 2 piece MAG pump
Thrust Pro trim
Other stuff
Specs:
Powerfactor Pipe
JAZ 2 gal tank
AG battery-so far
Thrust Pro trim
Other stuff
