I hope your air intake doesn't spit water into your carbs...I see how you have it and it looks like it will work the only thing it is pointed @ the carbs...maybe piont it back or something...I have 4 tubes that run forwart to the front of the hood and stop about 4 in. before the front and just dump...Mine will hopefully not swallow too much...Great job...
Ice, thanks for the pics. Unfortunately, by eliminating the lower hump in the hood, a lot of intake options were also eliminated. My suggestion to anyone who wants to do the totally smoothed over look would be to leave the lower hump in place and glass and fill the edges flush with the outer hood sides. This will leave more options open for a re-designed intake.
The intake (2" PVC) as shown is only partially complete. It's going to have a 2-1/2" flex hose coming off the tee and routed to the bottom of the carbs. Also, I have a 1-1/2" pipe at the bottom of the tee, which terminates in the under seat storage compartment for a drain (you can see this a few pics back).
As far as water ingestion, I think its going to work very well.......its the size that I'm a litle concerned about. 2" was the biggest I could fit without interfering with the steering linkage.
The 1-1/2" drain will also act as an intake when the storage compartment isn't full of water.
