I started chopping my X2 and couldn't stop!
hood mod
here is more pics...it won't help this build but maybe ideas for the next
I hope your air intake doesn't spit water into your carbs...I see how you have it and it looks like it will work the only thing it is pointed @ the carbs...maybe piont it back or something...I have 4 tubes that run forwart to the front of the hood and stop about 4 in. before the front and just dump...Mine will hopefully not swallow too much...Great job...
Ice, thanks for the pics. Unfortunately, by eliminating the lower hump in the hood, a lot of intake options were also eliminated. My suggestion to anyone who wants to do the totally smoothed over look would be to leave the lower hump in place and glass and fill the edges flush with the outer hood sides. This will leave more options open for a re-designed intake.
The intake (2" PVC) as shown is only partially complete. It's going to have a 2-1/2" flex hose coming off the tee and routed to the bottom of the carbs. Also, I have a 1-1/2" pipe at the bottom of the tee, which terminates in the under seat storage compartment for a drain (you can see this a few pics back).
As far as water ingestion, I think its going to work very well.......its the size that I'm a litle concerned about. 2" was the biggest I could fit without interfering with the steering linkage.
The 1-1/2" drain will also act as an intake when the storage compartment isn't full of water.
intake air
I was a little worried about air to that is why I left the original side openings operational!!! if you have trouble just take a hole saw and drill a couple behind the seat on the fire wall Ha Ha !!!! what is the color going to be????
I've completed what should be a final mock up. Here are some pictures of everything in place under the hood and the internal trim system. I was able to mount the stock trim system upside down below the steering deck and reuse the existing cable. The cable bracket will need another bend to work right but I don't have the cable yet.
There's absolutelty no room for the CDI now so going to use an electrical box from an SX mounted down low between the battery and carb.
Oh yeah, I painted it too! Wasn't going to go with the Kawi green again but I wasn't too happy with the color of my last one. The new color has much more of a yellow tint to it, which is what I wanted the 1st time.
Still waiting on some miscellaneous parts and fab some brackets for the chamber but is FINALLY almost done. I started it up today and runs good on the hose with no leaks. I'll hopefully be able to do a trailer test within a week or two.
#ZERO
Beach Bum
Florida - U.S.A.
Nice job, those tubbies blend in with the hull contour real well.
I'm curious to hear how it's going to handle with all the mods.
