SXRguyinMA
Life's a beach
- Leicester MA
starter work?
Would a stuck valve give the same symptoms?
:smokin:Would a stuck valve give the same symptoms?
this is a joke right?
Ignorant, maybe; joke, no.
I (obviously) don't know that much about engines, but my thought was that if the valve was stuck almost closed and when the piston was dropping it closed the valve and caused enough of a vacuum that a weak starter might not be able to overcome. And when the plug was pulled, there would not be a vacuum created. In retrospect, I can see that if the starter has enough power to compress, it would most likely have enough power to overcome a vacuum like that.
I guess I was completely wrong, and now I've learned something. Kind of what this forum is about I thought. :smile:
well at least when you flooded it with water you didnt end up with the scenario I did that became my avatar
<--- :banghead:
Ok who wants to tell him?:shhh:
Ok, once again excuse my ignorance, but I thought the reed valves were only on the intake side, which wouldn't keep exhaust from being sucked back in. Am I not correct about this as well?
haa.. i like your avatar every talks all this hype on stroking a motor and you de-stroke one..:laugh2: you just need smaller domes.. water ingestion sucks
but you avatar is great:thinkerg:
