then i just put that end into the hold and tighten right? I checked with autozone the only thing that they said they had was a harmonic balance, would that work well too?
Its hard to tell someone how to do it, in spite of it being very simple. You DO NOT just put one bolt in and screw it down though on the 650 - that was something for the 750.
Try and see if you can search the web for instructions on how to use the harmonic balancer puller - again, its very very simple to use but (IMO) tough to tell you how to do it. Unless someone wants to try.
Once you get the tool set up right, using 4 bolts (the one big in the center and the proper size three outlying ones), then you screw in the middle bolt to the point of popping the flywheel off. If the flywheel doesnt't pop and you feel like you've screwed it in as hard as you can (within reason), then take a hammer and give the middle (main) bolt a sharp hit with the hammer and that will usually break the flywheel free from the bit of rust and the tightness of the tapered end of the crankshaft and it all falls loose.
Look at the pic in Mouth's last post - set the tool up like this with the middle bolt (pointed end) into the end of the crank. Find the three smaller bolts that fit the holes in the flywheel and put them (in an even spacing) through those slotted ends in the tool and into the holes in the flywheel. AGAIN dont screw them in a major amount, you got a stator behind there - only about a half inch will do, you want good hold on the flywheel threads. Once the flywheel bolts are in both the tool and the flywheel, then start screwing the middle bolt - things eventually will all tighten up, keep the tool (middle bolt) straight with the crank. Like I said above, once you get it really tight and if it hasn't popped off by this time, then use the hammer and that shock from the hammer blow will make it pop loose.
Sorry for going round in circles here - not enough coffee in my system yet to be coherent.
