Hole in my boat?
I found a hole in the firewall in the back of the engine compartment. its beside the coupling on the pipe side. its about an inch in diameter. It looks like there was a paper sticker covering it at one time. My question is why is it there (is it from the factory), and isnt that letting water under my tray (I can see foam)? Thanks for the help! :confused:
('02 sj)
Proformance1
Liquid Insanity
New York Crew
And most likely if its anything like my 05, water is coming in from all the pipes going thru the bulkhead so sealing the two fill holes won't matter much.
pyro723
Daytona fireworks guy!!!
Louisiana
Yea those stickers suck! But even more then the stickers refoaming sucks even more. If you don't know what your doing I would think twice about doing it. Just seal up the holes and call it a day. IMO good luck with it.
Proformance1
Liquid Insanity
New York Crew
refoams suck, I'm at about 25hrs and still not done. Weigh the ski with an empty tank and decide from there. I did mine just to reinforce the sides and also because I was over 340 lbs RTR. Actually the more weight in the boat the easier it is to ride, at least in the surf! lol
