hillbilly550
Rich L
- Lewis Center oHIo
The pump stuffer is an aluminum fixture that installs behind the impellor on the pump housing stator. As I understand it, it increased pressure inside the pump and I would think it improves flow as it fills the cavity behind the impellor to allow for straight through flow. It also has 3 different cones to "fine tune" to your style of riding. I have only used the stubby "freestyle" cone and can't comment on the differences between the cones.
here you go http://www.tbmracing.com/web/index....category_id=8&option=com_virtuemart&Itemid=18
