Wouldn't be easier to use a pipe designed by Factory Pipe for a Superjet ...stock to limited?
I believe they call it their 'LIMITED chamber for a reason...I have used mod blaster chambers in the past a lot, but only with modified, ported, strokers, aftermarket Mukini's and av/race gas engines.
Stock carbs just don't cut it for modified engines as your to limited by the lean burn emission 38mm carb circuit, made by Mikuni for Yamaha.
Yes, you can run no screens also in the F/A, just make sure you have nothing that is loose and get sucked into the engine.
