- prescott arizona
So I got this 145 set back skat mag with a ti drivshaft and a 13/18 prop off a memeber here. After getting my motor set up and tuned it just didn't have the top end pull that it should, upon closer investigation, the trailing edges of the prop have some damage and apper to be bent, anyway, I can't get this prop off the drive shaft to save my life.I've broken 2 vises and have tried soaking it in penetrating oil, heating it till the prop was glowing red, used a 10lb hammer and also tried putting it in my cnc lathe and chucked up nice and close to the prop to eliminate the twisting of the drive shaft and hit it with the hammer, still no luck. Any other ideas guys?
