a year ago i built my sj and i have had no problems with it since i built it. yesterday i put on a brand new oem fuel filter and closed my top pipe screw because it has been running cold. well i took it out this morning and as soon as i took off it sputtered until i held it wide open for a while, then it would be fine. so i put brand new plugs in it and the same thing. i disconnected the heat sensor and that didnt help. this ski has been smooth through all rpms with no hesitation before and ill i changed was the pipe adjustment screw and the fuel filter. any help is greatly appreciated. my list of mods is below so you can maybe figure my problem out.
94 61x 701-all work done by groupk
bored 1 over with pro-x pistons
recreational porting
stock lightened flywheel
shaved head-170psi
46mm blackjack carb
groupk intake manifold mod
aftermarket reeds
factory limited b-pipe
jetworks flow control valve
dual cooling
solas concord 13/17
protec cdi mod
shaved head-170psi
46mm blackjack carb
aftermarket reeds
dual cooling
solas concord 13/17
protec cdi mod
