- Midland, Ontario, Canada
The shaft on the left was sold to me a few years ago as a used jetmaniac Superjet HD driveshaft, but when I installed it I had issues with it sliding too far forward in the bearings and it jammed up in the midshaft...so I shelved it and moved onto a different pump and shaft.
Just acquired the shaft on the right which is a known good jetmaniac HD Superjet driveshaft. You can see the difference in where the bearings seat, there is about an inch difference In the two but both shafts are the same length.
So know I'm not sure what the shaft on the left is? Anyone have any Input?
