LBE
Eddie Would Go.
- Charlotte, NC
Well I talked to a couple people recently about the aluminum top bracket on a FX1 vs a RN. The base bracket is the same and the handle pole itself is the same, except for length. The RN top bracket is 2 1/4 in longer than the FX1 bracket. I'm gonna be running a RN steering cable and top section on my FX1.
If you look where the "U" clip holds the cable on the bracket, the distance on the FX is shorter. Basically my reason for switching is this: When running an aftermarket turn plate, when the ball joint is put a "quicker" outer setting on the plate, the angle of the cable on the FX is greater because of the shorter distance. This causes the cable to bind on the FX.
Didn't know if this should be posted in another section, driveline?Tec?
Move it if necessary.
