it sure is Idok. looooong time no see man.
thanks for the responses. butti, when you changed the location of the tub, did you also change where it comes through the bulkead of the hull or did you leave a small amount of the gunwall in tact to make a riser with a couple 90 degree elbows to kee the stock local? Idok , if you could track down that pic and post it i would be most intersted in checking it out to have a ball park before i get chop happy.
