makejetskiinggreatagain
Brandon
you make it seem pretty easy pro-pulsion. thanks for the write up and pics
Ya that's my biggest issue, I just don't want to cut into my brand new ski. I'm afraid I'll somehow ruin it. But after reading about your experience, I'm considering installing them next winter when I get the time. It doesn't seem as scary anymore. I appreciate you taking the time to go over every detail and adding pics. I know others have done this, but you seemed to simplify it.Thanks guys. I don't mind helping out when and where I can.
FPF, it honestly was easy. A lot easier than I expected it to be, the hard part was bringing myself to cut into my hull for fear of scrapping something. There actually is nothing to scrap on the inside of where you will be cutting if you are using the Dremel like I did other than the cutout from the hull and some foam you have to carve out. Two things I should have mentioned before as well, wear long sleeves and a good breathing mask certified for small particulate like fiberglass and asbestos. The little white dust masks don't offer any protection for stuff like fiberglass and SMC dust.
I agree with you on structural integrity. I am the sort of person that will end up having a guilty conscience if I know that there is an area of whatever I am working on in need of repair and choose to ignore it. The thing I would be asking myself is not so much about re-doing foam at first, but getting the wet stuff out and finding out why it is getting wet. As far as rebuilding the tray to be strong, I don't think you will have to worry about that too much as it will pretty well be taken care of when you glass in the holds. As mentioned, I put down 3 layers of glass when I installed mine. I have heard of guys only using one to try and keep the weight down. To me, if the ski is powerful enough to make me happy the weight won't be noticed. Plus, if you cut out the tray using the Dremel disc method for the holds, the re-install and glassing over process should be pretty solid with minimal try material loss. Sometimes a job becomes much more than we ask for but if you clear up the issue now, you will likely save yourself from facing a possibly much larger problem down the road.
