- Windsor, Ontario
Only use it when parked? Not in transit?
Fair point!
Anyone ever try one of these?
Skilock SL25 PWC to Trailer Lock for Jet Skis and Waverunners
The SL25 Skilock is a lock used to secure your personal watercraft, jet ski or waverunner to the trailer bunks from underneath. Made from hardened steel construction makes the locking unit virtually impossible to remove without the key. The hardened steel lock combined with the star key locking...www.watercraftwerks.com
I have one I will sell you, will not work with my hitch hauler.Anyone ever try one of these?
Shoot us a text message at 928-846-7647 we can share pictures with you just keep in mind if you put an sxr 1500 on our unit you cannot also tow behind it unless you have our gorilla 2.5 which is made for the class 5 HD hitch receiversIs anyone using their EZ Ski with an SXR-1500? do you have any pictures?
On point and quick lmao was just bout to tag you ur supposed to be welding!Shoot us a text message at 928-846-7647 we can share pictures with you just keep in mind if you put an sxr 1500 on our unit you cannot also tow behind it unless you have our gorilla 2.5 which is made for the class 5 HD hitch receivers
Sxr 1500 weighs 552 lb dry!!! LolOn point and quick lmao was just bout to tag you ur supposed to be welding!
The sxr is that much heavier than a b1? I see people towing a ski trailer with the b1 on the hitch. Didnt think the sxr that much of a tank
This will be determined by your receiver rating . Our hitch-hauler will work.. however we cannot speak to the rating of your receiver. I can say that we have many customers that use our hitch haulers for an sxr 1500. as for the length you are correct this is a very long ski and if you're going a long distance it's probably not recommendedHi Chris:
Thanks for the quick reply. I had an SXR 800 and it was fine with the hitch hauler. I am a bit concerned about putting an SXR 1500 on the back of a 2 door Jeep Wrangler because of the weight and the ski length.
Sorry I should have asked this in the last post but can you tell me from outside to outside what the bunk spacing is and from inside to inside.
