Mile9c1
X-H2O.com
- Grand Rapids, MI
Try fogging oil.
Brings up another point. How can running the motor REALLY clean that crank GOOD after a saltwater sinking?
There is something to be said for being able to drain the water out without having to spin the engine over,the whole time you are spinning it over you are washing all the lubrication off the cylinder walls,crank bearings etc.No lubrication means metal to metal contact which means at the least premature wear on the components.
Not to mention if there is enough water in one cyl to cause a hydro lock if the other fires the first time you try to crank it after sinking it. You will get the old bent rod treatment and will be buying a crank. This is not rocket science here, just get the dang thing running ASAP after you fill it with water and fog the crap out of it after you ride it to clear out the water. The longer you wait the more parts you will probably have to buy sooner than later.
