NVJAY775
My home away from home.
- Gardnerville, Nevada, United States
Get the easy start capacitors for your campers AC. It should run it no prob if you put them on. It would not run my friends camper ac, until he put the capacitors on the AC....then it ran it and this was @ 95F+ degrees outside. Initial startup surge it needs the better caps, once it starts the gen idles down some.
I am also getting the PROPANE / NAT GAS conversion kit for it. After these horrific gas lines, I am making sure I dont have to deal with that ever again. Also buying (5) 40lb propane tanks to have for emergency cooking, heat, and gen power.
http://www.uscarb.com/accessories.htm
Thanks man! That's a lot cheaper than a new generator for sure. I'm going to try it out.
