do i need the stator gasket?
Metal4130
Eat, Sleep, Ride, Groove
Chicago
Do I need to use the gasket that goes in-between the stator and the engine cases? Even if I use an rtv sealant do i still need to use the gasket?
waxhead
wannabe backflipper
gold coast
yes
its a very good idea
if you dont run it and it leaks you will be sad
it takes up all the little imperfactions
i normally fit a gasket and then use grease on one side and sealant on the other
so it comes off nice and easy
wax, that is a good idea!
and yes...I remember Bernie trying to ride w/ out one. I think that was the year Slutty took his ski away and would not let anyone waste any more time working on it.
Y
yamaslut
Guest
bernie.... he was not mechanically inclined... no sir
lets not forget about the *thickness* of the gasket. that plays a role in how the bendix is seated. no gasket = tighter tolerance for the bendix. not sure if it matters.
SuperJETT
none
Funny you mentioned that. This weekend while replacing my bendix, I did some measuring to make sure everything was right with the washers and I came up with 2mm gap between the front washer and the flywheel cover bushing. With the spring holding it back, that's about right.
hahhahahaah
last I heard Pete said he was sailing. I hope he lets Pete build him a ski and comes and rides again...he is a very cool guy!
Y
yamaslut
Guest
Ross_C said:
hahhahahaah
oh yeah... brendog is cool as ********.. just not the most prepared guy
