- Reno,NV
Everything happens for a reason right....
So I do my season winter inspection and also wanted to install 62T JSS electrics and a scupper so I pull the engine , so after removing the flywheel cover and Flywheel I run across this oil/gas ...currently the engine is tilted backwards so the screw as indicator might only show half the height..
I have seen oil in there before but not this amount do you think the crank seals are bad.. ??
Thnak you for any advise
