cooling lines superjet with b pipe?
hhh
i run parallel cooling.
2 in from pump.
one to bottom of head pipe
one to mani. mine tee to 2 inlets on mani
top of head pipe to stinger tee overboard.
top of head overboard.
D-Roc
I forgot!
i have the ex. mani. tapped for two inlets so i tee the line from the pump and it goes to each side of the ex mani. two outlets on the head, one goes to the bottom of head pipe and comes out the top of head pipe, continues to a tee, one with a flow valve and into stinger the other end with a restrictor and overboard it goes. the other outlet on the head has a restrictor and goes overboard.
cattledog
EH TEAM RACING
toronto canada
thanks i am going with this way
icecoled007
Captain of this ship
Colorado
Old thread, but what do you mean by restricter?
long read, many combinations... http://www.x-h2o.com/threads/1667-B-pipe-cooling-routing-water-lines&highlight=cooling+lines
some more info... http://www.x-h2o.com/threads/91771-4-mm-restrictor-b-pipe
finding many control valves types and quick disconnects, but no picture of just a restrictor. i'm guessing you need something to hold it in the cooling lines?
View attachment 155464 View attachment 155465
I use another piece of tubing as an in line restrictor, a smaller piece of tubing fitted inside the 5/8" line will restrict flow just a bit.
