WaveDemon
Not Dead - Notable Member
- Hell, Florida
he made them. why? because he's ollie.Hey Ollie, where did you get those stainless steel sleeve inserts on your GP800 engine mounts? That looks like a good idea.
I do understand that I overdid it because more than likel;y the insert would rip out first but I was also considering the worst case scenario or years of the hull mounts being subjected to the full pounding.
Is what you are after a TOP motor mount? something that bolts to the head with a rubber body tha can locate and fix the strap to the engine while bolting to the KK's? Like a transmission mount that goes between the crossmember and the tail of the trans?
I say foam the engine in and leave some room for air to get to the carbs and you are done my friend! Plus it can never sink! even when upside down! LOL
now youre onto something. :bigeyes:
almost the same.I think we are overthinking this. Flip a mount over. There is a hole through the rubber + into the bed mount.
Put a bolt throught the bottom of the mount + a couple of turns into the bed plate mount.
You are done.
It will stop the mount fully seperating.
Mount still works the same.
-O
I'll test it. I 3/4 roll all the time so no worries about the stress of the test.whos is gonna test pilot the new product? who has skill enough to warrant them FULLY abused, I mean tested?
yes but I think the bolt will stop large lateral movement too.aren't they more for lateral movement not straight up?
send your money to macmaster. I'm thinking it'll be about $10-$20 per ski.i'll test 'em too..how much $$ do i send, and who do i send it to. :bigeyes:
i'll be throwing some BF Pancakes over the next 2-3 months.. GUARANFKNTEED
