Blowsion One-way Valve
Postma
Delivered
Plymouth, MI
Does the Blowsion One-way valve glue onto the end cap or is it clamped on? The pictures on Blowsion's appear to be glue, but I just wanted to make sure before I started into the repair. The outside end cap is damaged on my ski and I would like to replace that part or put a scupper there.
Here is a picture of what I am working with.
snowxr
V watch your daughters V
Waterford, MI
I tore one out of a ski recently because the valve leaked really bad, and soaked the surrounding foam, too. The end cap was glued onto the tube.
Postma
Delivered
Plymouth, MI
I have one of those on an fx1 and it works a charm...
honestly, I'd leave it....its not hurting anything
definatly do not go scupper over the 1 way..
Ya it works great! Gets the water out fast and doesn't seem to leak. I was just going to take the end piece off, clean up the damaged area to make it look nice, and use a scupper as an end cap. So essentially I would be using both the one-way valve and the scupper.
