Y
yamaslut
Guest
ok, I just came up w/ a new concept for bilge operation in the surf...
my setup
I run a single 2.5" scupper valve and a single Mayfair bilge pump (500gpm)
My idea is this:
I went to a Marine surplus store and bought a lanyard switch that is a "normally closed circut", meaning w/ the lanyard pulled it's "closed" and w/ the lanyard engaged it's "open". I don't like to have the bilge running all the time since, you don't need it and it robs power (i think)... Anyway, I personally don't like it running unless it needs to be... The idea is if I'm riding along doing tricks and surfriding, I don't need the bilge, right??? So I wired up the switch and mounted it to the front of my tray and attached the lanyard to my lower vest. W/ the lanyard to the bilge switch, the pump will only turn on when I'm seperated fron the ski, the only time it needs to be on IMO... Everytime I sink or hydrolock my motor, it's because I didn't have the bilge on and it took on water up side down...
btw - the switch was $12 and looks to be decent quality (waterproof, of course)
disclaimer:
This is just a different way to do things... I realize most of you will just turn it on and off, but I thought I would share my idea...
my setup
My idea is this:
disclaimer:
