Super Jet Best F/A setup for surf?
Mr Bojangles
Lord of the Dance
I guess I should update this, but stock would never fit my setup, the guy before had some crazy adapter for the stock 38, to go to a 4 bolt FA setup, that was stripped out allen heads, and they are set at a different spacing that would align with the stock FA, so I wound up making my own design. Its at the shop now being made, and it uses the stock FA screens, and is similar to the stock single carb FA, just aluminum, and with a lower profile
motozachl
uPsiDeDoWn
JAX
Stock!!!
Get a hold of motozachl in here....he just bought a big bore square from Michigan and whoever did the hood seems to have done it right! I am sure he will give you some pics.....but he needs stock F/A' also.....he gets some water in on big waves days or doing subs in flat......
IMO even if you can get those pile of crap AM F/A's to be water resistant (outerwears) both of them are high cost for sure replacements and they WILL eventually fall apart!
This is true, its really not that bad because the spiderski just plain sucked in water.....but I can still tell some moisture is getting in the carbs from water sloshing around
