- Green Cove Springs FL
I first rode them cut straight off the 2x4 but could not slide the rear of the ski! Made a huge difference. So I cut the back 8 inches or so off (if you look close in the pics you can see the curve at the back). Then turfed them. Haven't had a chance to ride this version yet. Maybe tomorrow. Side note, a guy I have ridden with a few times has a similar set up but his rails are further forward, they about line up with the hood both front and back. He is a much better rider than me so he wants more slide. His are about the same width (3.5) but have less vertical part and the front and back 8 in or so are just a straight edge. I was worried about that edge (I'm a noob and spend a lot of time falling OFF the ski!) so I wanted the vertical part as much as I could get it. The front edge may slow me down a little but usually they are out of the water. Anyway, what I'm working on so far. I was really surprised at how much more stable it makes the ski and how it makes you float through the white wash! Curious though how long they will put up with poor form landings (landing too flat). I'll let you all know. Planning to abuse them in Daytona in two weeks!
