I updated the switch location again this weekend after getting stuck in the surf with my EPIC set on crazy. I lost track of what curve I was on and was doubting I was on my surf curve and switched it for our last session. Between exhaustion and the chopped up surf, my "Crazy" curve was just too much for me so I had to come back in early. The switch in the e-box was good and safe but very inconvenient to access. Since I developed the "Surf Armor" toggle switch I am no longer in fear of having the toggle outside the e-box so today I moved some things around.
The first thing I had to do was build a new "Tidy Bilge" harness. The old one didn't have enough room for 2 more wires so I built a new one that had a longer drop to tie into the new cable running up to the handpole. I then built up a "Surf Armor" toggle switch with long enough leads to run from the handlpole down to the e-box and built a mounting plate that will bolt to an existing location on my RRP handpole.
All in all I am pretty pleased and can't wait to be able to switch between curves on the fly. :biggrin:
P.S. Thank You for the tip Josh, X-Scream motors absolutely love 32deg of advance :bigok:
