Another dang convert.......
Crab
thanks darin...noswad!
Seattle
The stock carbs probably have the best low end response with stock reeds, but with the bigger carbs and reeds that thing would be friggin insane on top with the drypipe.
My plan was to send off the cylinder to have the port work done and run the 44's more than likely. I wouldn't touch it for now. It should hit as hard as most of the ski's you run with.....used to beat the crap out of shawn's ski's....haha
FYI. The pump in that ski is out of a 750sxi. I beat the crap out of the skat impellar that was in that thing and didn't have the tool to remove the impellar. Just swapped out with a pump I already had and it had the solas 13/18.
Crab
Seattle
That explains the extra cooling fitting going thru the hull.
I pulled all of the bling off of the ski before I sold it and put it on the GF's ski.
I kinda did the same thing to my square, only it involved malt liquor and whatever spray paint was at my friend's house.
I think I'm gonna go dual, I think it will run warmer than I want later this summer.
Well hopefully I will get moved back down there before summer is over and tear up some crap with all of the Idaho boys. Going to be riding in Minneapolis for the next couple of months. From what I see, they take it pretty serious up here as well.
Crab
Seattle
Luke, when you reroute the pisser from the back of the hull that comes off the head, isolate it so you can see how warm the water is coming off the head, that will tell you if you need the dual cooling or not. The water coming from the chamber will give you a false reading.
I felt the cylinder after running for a while, definitely warmer than the square.
Motorheads5
Livin the generation gap
ketchikan alaska
On the plus side they don't take as much energy to ride (flatwater anyways, Idk about surf)
I have never been on a sxr, but I plan on it real soon, Tanner and his buddies have been riding the last couple of weekend's in saltwater I have been in the 16' lund lol too damm cold for me. We are waiting for the lake to thaw still can't even get to it other than by snowmobile .Good luck with the new boat I love Kawasaki but I am going to build that RN I got from the Crab as a freestyle boat I have no doubt I will love it.
