the WaTeRhAwK
fryin' up a/m electrics..
- okc
It is a bit lighter, but you're not talking major savings here.
A SJ needs about 4 cuft of foam, so when using 3lb foam you're at 12lbs total.
yeah, but you ain't soakin' polystyrene, either. when you get into talkin' weight savings because your foam isn't taking on water through stress-cracks in the hull from aggressive riding, yeah, major weight savings.
