Adding a bailer fitting to Thrust Ez-Flow Pro Trim System.
Hey yaw,
I just received my new Thrust Ez-Flow Pro Trim system today and noticed the reduction nozzle doesn't have any fittings for the stock SJ bailer system. I would really like to keep this feature and was wondering if anyone out there has found a good way to add the necessary fittings to use the OEM bailer? Any pictures would be greatly appreciated.
Michigan
You could buy an stock pump nozzle that is set up for trim. The one that is used for xmetal trim or C.A.T.S trim. I was using the xmetal trim with a 62T exit nozzle and switched to the thrust trim but didn't change reduction nozzle because I already had it taper bored by zero, thrust trim ring bolts right up to if if I remember correctly.
Exit Nozzle Yamaha - 62T-51318-01-94
This one's a little crusty but you get the idea
https://www.ebay.com/itm/Yamaha-700...:n1AAAOSwGvhUIXQe:sc:USPSPriority!49412!US!-1
USA
You could buy an stock pump nozzle that is set up for trim. The one that is used for xmetal trim or C.A.T.S trim. I was using the xmetal trim with a 62T exit nozzle and switched to the thrust trim but didn't change casino spiele mit echtgeld because I already had it taper bored by zero, thrust trim ring bolts right up to if if I remember correctly.
Thanks!
JetManiac
Stoked
orlando
The Thrust reduction nozzle already has a bore as large as most bored nozzles. Also the sides are thicker that a stock bored nozzle with larger thicker boses for mounting the trim ring, so I would stick with the Thrust nozzle and just angle drill and add a siphon tube instead.
Yea this is what I was planning on doing. No sense in not using the brand new shiney Thrust reduction nozzle. I have access to a full machine shop, so angle drilling the nozzle isn't a big deal.
