Super Jet A/M pole brackets for stock poles
Just need some opinions on the lowest bracket out there for single poles. CG wise not lowest price, although both would be nice:smile:
I am looking to reinforce a stock pole. I prefer the look of the stock pole and it's function. I also want a pole that's light and has some foam in it.
Those are the main reasons for going with a stock pole. I am looking at the different A/M companies for single breather brackets, but it's hard to tell which is the lowest so I wanted to get some opinions.
Please comment on strength,durability, cost, fit etc...anything you can think of.
I am leaning towards the x-scream or blowsion for now.
Again...thanks so much for your input.
AtomicPunk
Lifetime bans are AWESOME
Largo, Fl
I like my R&D bracket. Not sure how low it is, but I cant imagine it could be any lower. The bolt just clears the top deck when sliding in.
It also has a provision for the OEM pole "holder upper".
i have a wcf topdeck conversion also and i am going to be running a stock rn pole. I am using a waterdawg kustomz billet pole bracket they claim to be the lowest out there. i havent ridden with it yet but it is a very nice piece and fits very well. my ski is upside down right now because im doing some work to my pump cavity but i can snap a few pics after this weekend i hope. if it helps im also using it with the wdk "diablo" lowered hood and nose piece
link
http://www.waterdawgkustomz.com/proddetail.php?prod=SJLWBRKT&cat=5
link
Thanks guys...
That waterdawg bracket is my favorite so far...I really like the pole stops as well.
You bring up a good point as well, I need to be able to get the bolt in:):)
I will measure my ski tonight to see how tall the sides are from the flat nose area.
i found a couple pics that i had from when i was mocking everything up. nose piece does sit flat not sure why its crocked in the second pic
Sospikey
Trying to get upside down
Sweden
x2! It is lower and also a tad bit more forward. Nice bracket!
227
Its all about the surf!
Oceanside, CA
Yes, if your running a stock pole, then the R&D Bracket WAS the best choice out there because it was so versatile. I say WAS because unfortunately it is no longer available. R&D said they stopped production because the watercraft market is so small. I was lucky to get the Black one pictured, they had to piece it together from some demo parts. The R&D's advantage was that it is the only aftermarket bracket that could still use the OEM pole lock and, the best part, is that it can be disassembled into three pieces so adding a pole spring was a breezy one man job- install the bracket sides, pivot bolt with the spring on it to the pole and then simply bolt up the base base to the sides from the bottom-done, it was that easy. It'd sure be nice if someone would step up and make another bracket which can be disassembled and use the OEM pole lock, hint, hint Cold Fusion.......
AtomicPunk
Largo, Fl
Great idea for the spring.. I wrestled mine in by myself.
I forgot the pole position is a little forward too.
R&D is in 1st place now:)
if they don't make then anymore, maybe I can find a good used one out there. I'll make my decision tonight.
a one man spring job is unheard of in these parts! ...ha ha
Great replies as I always say...
Looks like it's going to be hard to find the R&D bracket. It sure would be nice to gave the option to hold up the pole. Especially with an internal fuel filler.
I won't need the bracket for another month or so, maybe I can find an R&D one by then.
I was going to mention the CF as well. Looks like JetManiac beat me to it!
Cold Fusion and Jet Maniac are some of the best guys in the industry to deal with.
Tyler Zane
Open Your Eyes
im running a stainless 615 bracket. its so low and forward that you have to attach it to the pole before you mount the bracket to the hull. can be a pain but how often do you really need to disassemble it? i remember it being half the cost of most others out there as well.
