800sxr lightweight upper deck build(paint and graphics)
So Cal
This my 2009 ski build. The parts list goes like this.
HULL-
-QSM light weight upper deck conversion
-trued -2.5 bottom deck
-9lb QSM freestyle hood
-Dual suppers
-Custom ex tubing
ENGINE-
-880cc QSM stroker kawasaki engine
-Dual novi 48
-Msd total loss
-special b-pipe chamber
-vforce reeds
PUMP-
-Custom set back skat trak impeller
-custom ride plate
-skat trak mod freestyle trim
-tbm pump cone
-works intake grate
I will post some paint pics during the week. The pics below are of when I cut the old deck off and the first test ride.
So Cal
Its a shop out here in so cal. Its called Quickstyle Motorsports. My name is Larry Sarinana and my partners name is Stan Howton. I have been competing in freestyle for a while and finally have the resourses to start making my own freestyle products. My partner has about 30 plus years doing custom paint. He has had some work featured on discovery"s biker build off show. He is doing the paint and I am excited to see what he turns out. The shop web site is on the way.
So Cal
just put it on the scale and it was 100.5 with foam, ex tubing, pump inlet, cooling lines, steering cable mounts/ tube, dual supper valves and trim cable tube. Its almost ready for paint. Weighed another sxr just the bottom deck and it was 96.0lbs
So Cal
The upper was made of epoxy and glass. Yeah we made the bulk head and then used plexus to bond the hull. Didnt weigh just the top but it was very light. The hard part was getting all the fu@#ing glue off the bottom deck. That alone weighs a ton.
So Cal
No its not getting the round nose. The green dragon was sacrificed to make molds and tempaltes for some new stuff. Been really working on the bk flip so after its all painted and assembled its on. No more testing just riding.
So Cal
Finished the nose peice. Flushed out the fuel filler and blended the nose. The plan is to mount it with a aluminum bracket in the rear and rivit or bolt it to the bond line. Then turf the entire bold line of the ski.
So Cal
The sxr is getting a metalic kawasaki green with graphics. This is a pic of the silver base coat. Decided to paint my wifes square nose at the same time. So lucky for me I get to do everything twice
So Cal
Here is a pic of the green. There was still some paint in the air so the pics not that clear. Today the clear is getting cut and the logos, and graphics(black/silver) are going on.
