- Annapolis, Maryland
the weight of the mid shaft will naturally pull the assembly down
I know your right the weight does bring it down a little. i just did that so i could show the left and right mis alignment.
i had a problem lining up my pump on my rev... i called jeff.... still waiting on the call back... that was 18 months and two skis ago!
Thank God for X-H2O!
THE BULKHEAD IS NOT FLAT. IT IS RECESSED FOR THE MIDSHAFT. Check the allignment again. Is it a new midshaft housing? That motor shakes more than a stock motor as well. Its the nature of the motor. But your midshaft should not be getting hot. Was your drive shaft straight out the hole in bulkhead and pump bolted down completely tight when you installed the midshaft? If so, did the midshaft slide on easilly and bolt right up without having to move it side to side or up and down? Is the motor lined up propperly? Did the rubber dampner move with little force inside the couplers when the motor was fully bolted down? It should.
is your driveshaft straight and the splines on bothe shafts in good condition? all things I would check. as for the raddle I would make sure the starter bendix is disengaging as well.
Justin check your pump seal and also what does your wear ring look like? I'm sure some of it is the prop too. 13/17 in a stock pump behind a 904 isn't gonna cut it in my opinion.
