bored&stroked
Urban redneck
- AZ
Highly doubt its a 44mm carb as the wetjet 46mm carb and manifold have slightly different mounting pattern, so a normal 44 will not bolt on. That's what I've read.
Ok thanks that helps. So should I go with b pipe jetting? Is the b pipe jetting meant for single or dual 44? Also when it says High speed screw 1 2 , what does that mean? 1/2? 1-2 turns? Thanks again
Thanks. I can't imagine the b pipe or my sizzler would have that different jetting specs? Ill post in a bit what is in my carb now.
