- South Florida
Empty your mailbox.
the noise will go away if you grease the muffler bearings.
Seriously though, I can't believe you haven't found the culprit yet. I bet the noise is going to be something stupid when it finally rears its head.
I didn't follow this build all the way, so my questions are: Did you use stock OEM SJ Yamaha rubber motor mounts or aftermarkets? Do you have kenny keepers?
I have found that both of these can cause vibration problems.
Rode for a little while today. Even tried for a backflip. I'm not sure how far around I got but it felt a lot further around than I've ever gotten off big boat wakes and no trim. I didn't attempt a second try because I almost sunk the ski. The ski was upside down for 4-5 seconds while I regained a sense of where I was in the water. Turned the ski upright and the motor was sputtering and the nose was riding really low. First things first, I need to reroute those hood tubes to the bottom of the hull so it doesn't suck up so much water. Then I still need to add some flotation to it.
i want to see vid. I'd like to see the boat wave you are attempting this from.
l think l saw a pic of your hood with the hoses coming out at the rear.And then you routed them to the top(of the hood)? You going to just let them hang down?
