Chewed up piston: Is this Rod Bearing Failure?
the WaTeRhAwK
fryin' up a/m electrics..
okc
crackhead-there are no marks in the middle because there is ALOT of clearance in the middle!!! U know-the combustion part of the dome? LOL
that makes absolutely no difference. if a chunk of metal from the bearings is jumping around in there, it's going to ping the hell out of every single bit of surface area there is. not only that, but it's going to look "gouged", not "cooked" and melted.
it's detonation brutha : ) bet.
Piston broke off and made the ring bounce around (Note the curious absence of marks outside the squish band area):
Screw came off the reed cages and bounced around (again, note the absence of center marks):
GIL
Power In The Hands Of Few
Cullman AL
it's detonation brutha : ) bet.[/QUOTE]
How much do you care to lose???? I will bet u 25.00 paid via paypal pending pics from Shonuff!!!
Shonuff
I've got the glow
Memphis
Goodbye needle bearing cage. Hello effed up piston.
the WaTeRhAwK
okc
well, I guess i was right the first time...lol oh well at least I had my bases covered. : )
still, usually when I've had a needle bearing take a holiday like that, it jabs the hell out of the entire surface of the piston, not just the outer edges.
GIL
Cullman AL
Travis-I am awaiting the most famous words on the X- 'Gil, you were right once again'.
TB
NOTHING IS EVER PROMISED
Grand Rapids, MI
gil i have been a member here since the x was like 2 weeks old and i don't think i have ever seen that statement before.......last time i seen you your boat was on fire:biggrin:
GIL
Cullman AL
On fire as in runnin good? Or that 1 time at bandcamp? LMAO
the WaTeRhAwK
okc
well, you were, sir.
...but I was "right" before you were....lol :p I just changed my mind like a dumbass.
also, your reasononing for your assumptions weren't on a very "solid" base...lol like I said I've had bearings and cages go and not just d!ck up the outer edges of a dome. I've had a few come out looking like the entire dome was attacked with a pick axe.
GIL
Cullman AL
I am just happy that Shonuff has admitted to Yamaha ownership and about to be the proud owner of some Jetworks Power!!!
the WaTeRhAwK
okc
ditto that.
I will be glad when I am too.
